4x10 EHydro Fault Code 11
/ 4x10 EHydro Fault Code 11 #1
mvanhaerents
S.E. Michigan
Deere 4410
I just thought I would post some information if any of you out there get a fault code 11 and the tractor stops moving in either direction. If you unplug any of the following sensors (MFWD, flywheel, forward potentiometer, reverse potentiometer, TPS) and check the voltage from the orange to the black it should be 5.0 volts. All of my sensors were reading 2.5V. Unplug the MFWD and Flywheel sensors each separately and see if the voltage returns back to 5.0 volts. My flywheel sensor had gone bad, and must have been pulling current to ground and lowering all the sensor's voltages. Replacing the sensor fixed the fault code 11 (short,short,long,long) and the tractor moves once again!
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
2009 Polaris Ranger 700 (A64127)
2009 Polaris...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
