Traction 4wd
   / 4wd #1
Rbarry419
Mahimdra emax 22
Any suggestions my emax22 4wd will not engage due to 4wd and hi low levers being stuck together
   / 4wd #2
Is it normal for the levers to be stuck together on this model? If not you should consider investigating why yours are hung up. Your dealer may be able to offer some suggestions.
   / 4wd
Not normal should move freely
   / 4wd #4
What I did on mine when they were sticking like that was to lube the ends. Down by the shaft coming out of the transmission.
   / 4wd
I’ll try that and see what happens thanks
   / 4wd #6
Sounds good! Let us know if it helps the situation!
   / 4wd
Soaked it with fluid film let everyone know what happens
   / 4wd
Sprayed all connections let sit 24hrs no luck
   / 4wd #9
FF wont work .... Try Kano Kroil Penetrating Oil or some other rust busting penetrating spray.....
   / 4wd
Picked some up today and got some ideas from dealer, going to try a few things and get back to the feed.
2014 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2014 Ford F-550...
2021 Acura RDX SUV (A50324)
2021 Acura RDX SUV...
2018 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2018 VOLVO VNL...
2014 Dodge Journey SUV (A50324)
2014 Dodge Journey...
2016 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2016 VOLVO VNL...
2019 CATERPILLAR 308 CR EXCAVATOR (A50458)
2019 CATERPILLAR...
