4WD won't disengage
   / 4WD won't disengage #1
wmwbutler
Kubota M7040HDC
2012 Kubota M7040. It stays in 4x4 all times. The mechanism operates smoothly and all linkages are in place. The pin entering the transmission turn only a slight amount. But that looks normal cause of the stops in place. I have tried lifting front wheels of ground and driving backwards, but it still stays in 4WD. Any suggestions?
   / 4WD won't disengage #2
I would disconnect the linkage to the front wheels and see if you can disengage the fwd by hand by manipulating the final link that goes into the front axel. Also, is your locked dif disengaged?
   / 4WD won't disengage #3
Not sure how your tractor 4wd engages but my BIL’s tractor had the problem, an L model of some type, and it turned out to be a broken shift fork. My FIL used extreme force trying to force it into FWD when things weren’t aligned and snapped the fork. Another BIL and I tore it apart, found the broken parts and replaced. But it is open platform which made it about 2 hour job to get it torn down.
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
2017 E-Z Beever M12R Towable Brush Chipper (A51691)
2017 E-Z Beever...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
JOHN DEERE 1705/6700 (A53084)
JOHN DEERE...
2010 JOHN DEERE 1110E FORWARDER (A51246)
2010 JOHN DEERE...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
