4WD starts clunking while in reverse
   / 4WD starts clunking while in reverse #1
Heavyquip
New Holland TC29ss
Question: the other day I was hauling tree debri with my front bucket w/a set of forks. I had it in 4WD backing down the street a short ways and the underneath started clunking, so I quickly stopped and worked it out of 4WD. Now it does the same while in 4WD, only in reverse. Anyone have an idea?
   / 4WD starts clunking while in reverse #2
Do you have U joints in the driveshaft for the front axle? I would check them.
Thank you, I’ll check them out. I haven’t had time look over just yet but I’ll start there
   / 4WD starts clunking while in reverse #4
I hope it'll turn out to be as simple as a U-joint or two. A number of things can take offense when using 4WD on high traction surfaces.
I put mine back in 2WD as soon as having filled the loader bucket with dirt, for example, before turning, to help protect the weaker front axle which now has high contact pressure (lots of traction). And that's on loose dirt.
Have seen too many break their front axles while four wheeling after not switching back to 2WD when 4WD isn't needed.
Utility Trailer (A52377)
Utility Trailer...
2015 Caterpillar TL642C (A53317)
2015 Caterpillar...
2016 R and R Products 331 LP Reel Mower (A51694)
2016 R and R...
2020 Freightliner M2 106 Elgin Whirlwind Series MV Street Sweeper Truck (A55852)
2020 Freightliner...
1449 (A57192)
1449 (A57192)
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A54814)
2014 Peterbilt 384...
