4WD Rear axle mount grease
   / 4WD Rear axle mount grease #1
kingreboog
Killeen, TX
Kubota MX5800
While doing routine greasing on a MX5800 I noticed a grease fitting on the mount at the rear of the front axel. Didn’t see any reference in the owner manual. No vent plug on opposite side from Zerk like the front axel mount. Won’t accept but the smallest amount of grease.
What’s going on here?
   / 4WD Rear axle mount grease #2
At the pivot in the center of the axle? The M59 has an adjustment for pivot wear at the front of the pivot and two zerks - one in front and one to the rear.
OK, I looked it up and sure enough the MX5800 has basically the same front axle design.
I see what you mean by the front having a vent #120 but not the rear.
And then there is that odd plug #20. What the heck is that?
I don't know quite what is going on there. Maybe we can figure it out.
Here is a link to the exploded diagram:
   / 4WD Rear axle mount grease #3
BTW, here is the M59 front axle. Interesting that on this one I can't see any grease vents on the exploded diagram, but I'll look there tomorrow.
It's a separate venting issue completely, but I see that this diagram shows that the front drive axle of the M59 is vented up to the frame while the MX5800 diagram doesn't show an front axle casting vent. It must have one...
   / 4WD Rear axle mount grease #4
Since I was unsuccessful injecting grease, I tried removing the Zerk fitting to test it’s function. Could not budge it. This is going to keep up at night.
   / 4WD Rear axle mount grease #5
I wonder how many owners do grease those two fittings and also make the front axle play adjustment?
Kubota must have thought that pivot was important because there is a surprising amount of sophiticated parts, fits, and engineering that went into that simple axle pivot. It's hardly mentioned in the manual.
In case you do get those two "front axle support" zerks lubed, there are a couple more zerks down there that are part of the 4wd that you may not have found...I found them on a European maintenance chart for our tractors where it mentions something they call "front axle gear case supports" and says there are two zerks. It is one of the few places that Kubota specifically calls for moly EP grease, and I'm not even sure I've ever greased it.
rScotty
   / 4WD Rear axle mount grease #6
Did you get it to take grease?
Here is that Lubrication diagram and accompanying text notes That I mentioned.
Who would have guessed that there are 7 points under the seat to lube (#11).
I'm going to take a look at the throttle cable tomorrow (#12).
rScotty
2007 POWERSCREEN CHIEFTAIN 2100X INCLINED SCREEN (A53426)
2007 POWERSCREEN...
2011 INTERNATIONAL MA035 ROUSTABOUT TRUCK (A52472)
2011 INTERNATIONAL...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2012 Honda Pilot SUV (A51694)
2012 Honda Pilot...
2001 Club Car Carryall Utility Cart (A51691)
2001 Club Car...
UNKNOWN 16 T/A TRASH TRAILER (A52472)
UNKNOWN 16 T/A...
