4WD indicator and Dash Volt Meter for XR3037HC
   / 4WD indicator and Dash Volt Meter for XR3037HC #11
I don't know exactly how it works on the LS but on my Kioti it is a large electromagnet that is right by the foward pedal. When energized it attracts the pedal and prevents the forward pedal movement.
   / 4WD indicator and Dash Volt Meter for XR3037HC #12
Good job George! Very nice addition to the tractor.
   / 4WD indicator and Dash Volt Meter for XR3037HC #13
Sweet! I've got my stuff ordered. Gonna do the same thing. Are you worried about the limit switch getting wet or dirty? I purchased a waterproof one just in case.
Which switch did you order?
I'm not too concerned but if it fails I'll have to come up with a different location to mount a similar switch.
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
17307 (A55853)
17307 (A55853)
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
