rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 8,291
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
Hello ALL!
SamofSweden started an interesting discussion in the thread "Kubota 7040 question" about Front to Rear tire sizes for 4wd tractors. It seems to me that the subject is one that affects all 4WD tractors, so I thought I'd start a new thread.
Here's where we were at this morning....feel free to jump right in.
Hello sixdogs, rScotty here. In a earlier (12/11) post on the "Kubota 7040 question" thread I've wrote down some methods I've used for figuring out the Front/Rear gear ratio and the rolling circumference tire ratio. Hopefully it will check what you have written down. Take a look and see ......
I've no idea why manufacturers make these F/R ratios such a secret. They are are at least as important as things like lubrication charts or internal motor part clearances - but for some reason the ratios are hard to find and hardly ever discussed. It would seem to me that the way the F/R ratio changes with Ag tires on the tractor versus Industrials or Turfs would be of great interest to the customer. It sure has a big impact on the way the tractor performs.
Continuing where we left off, generally the whole 4wd system will be dominated by the rear wheels because they have the greatest traction. So that relative to the rears, you then want the front wheels to always be rotating at either the exact same ratio as your rears or "pulling" slightly (higher ratio) so that you always have steering control. Having the ratio exactly the same front to rear would be workable and just fine....except for times when the relative traction, or tire wear, or inflation, would combine to make the rears overpower the fronts - which would result in loss of steering. So in order to make sure that you always have steering, the front tires are usually given a slightly higher ratio. The closer to 1:1 the better, but it must never be less. So as you say, the result is usually more on the lines of 1.02:1 all the way up to 1.1:1. That's a 2 to 10 percent higher ratio - just as we've all heard.
The trouble is that 2 to 10 percent is a rather large spread. On one of my tractors (Yanmar 336D) I got curious enough to try different tires and found that at the low end of the ratio - that is when the ratios are nearly equal - there s some loss of steering control and skidding when turning on sloppy surfaces. On the high end there is a huge amount of tire wear and stress on drivetrain components. And all of us have seen what happens to a nice finished grassy lawn if we drive over it and turn around in 4WD as opposed to 2WD. Folks who use belly mower tractors for lawn mowing are very aware of this.
It gets worse. In practice, nobody can really nail down the right amount of extra "overdriven front ratio" to design for because it is so dependent on inflation, wear, and surface traction. IMHO, Variable Ratio coupling is the real answer...that's what AWD cars use. But Variable Ratio is expensive and most of Variable Ratio systems reduce ultimate traction. So for a simple ol' tractor the best the manufacturer can do is change the Front to Rear gearing either in the transfer case or differentials enough to make sure the final ratio always favors the fronts enough to keep it pulling from the front end and therefore the steering working right. Common practice is to do this by giving the front end a 3 to 10% higher ratio than the rears. And then to overbuild the U-joints and transfer case pieces enough so that they can skid a tire as needed without breaking any transmission components. BTW, that is another reason why AWD vehicles have fluid F/R coupling....and so should tractors....but that's another story. It's also why a tractor tranny can be hard to shift out of 4WD sometimes.
At present, most tractor manufacturers seem to just tend to build the drivetrain parts oversize (hopefully) and let the machine just go ahead and skid a tire when turning on a hard surface like asphalt. Trading tire wear for mechanical wear.
I'm surprised this ratio thing isn't more discussed. It sure has a large effect on how we use our tractors.
I think I'll post this here and also use the message to start another thread on Front to Rear Tire Ratios.
Be interesting to see what others think.
rScotty
I can almost remember how to do the calculation off the ratio and the rolling circumference of the tires involved. I have it written down and that would refresh my memory if you get in bind--and have the ratio..
If you look at approved tire sizes for the 7040--or anything--and compare the rolling circumference to each other, you will find the front is 102% to 103% of the rear after the ratio is factored in. The front pulls the rear or you grind up the gears. That's why they say to stay out of 4WD on hard pavement or you'll wear out the front tires.
rScotty
