4WD front oil level bevel case and gear cases
   / 4WD front oil level bevel case and gear cases #1
johneic
Paducah (West) Kentucky
JD 3038e, Bolens-Iseki G174 2 Cylinder (early), Kubota B7200E 2WD belly mower
I can not find a level plug anywhere on the front end (I have the manuals and they are no help).
I have filled all three holes up to the top but am concerned that there may not be enough room for expansion of the oil.
Is there a built in "air space" above all three holes?
   / 4WD front oil level bevel case and gear cases #2
I'd fill the center housing about half full.
   / 4WD front oil level bevel case and gear cases #3
What make and model of tractor are we talking about
   / 4WD front oil level bevel case and gear cases #4
If you have the manuals it should tell you that the bevel case takes 23.36 oz
and the gear case takes 8.32 oz.
Sorry, I should have mentioned, it is a TX1500, G174 early 2 cyclinder
KJ 42'x30' Metal Storage Shed (A50121)
KJ 42'x30' Metal...
Mission 6" Centrifugal Pump (A50121)
Mission 6"...
Airco Tig Welder (A51691)
Airco Tig Welder...
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
4-27x10.5-15 Hauler Skidloader Tires & Rims (A50774)
4-27x10.5-15...
