4WD (dis)engagement lever?
   / 4WD (dis)engagement lever? #1
S854
Helena, MT
‘67 MF 135 Deluxe / ‘22 Kioti CK2610 HST/Bad Boy ZT Elite 54”
Getting used to the new tractor, I’ve found when, and when not, to use 4WD (what’s the correct term for 4 wheel assist?)…
I’m typically in 2WD, then engage 4WD (when needed) by pressing down on the engagement lever with my heel… easy-peasy…
What I’ve found inconvenient is going from 4-to-2WD… I need to reach down and pull up on the lever… sometimes while driving/weaving to get the gears to release tension… not necessarily easy on this old back…
Is there an easier way to use the OEM lever? Something I’ve overlooked?
Right now I’m rolling around in my mind a small, “teeter-totter” style lever…place one end of the teeter-totter under the selector lever and use my heel on the other end to raise the selector back to 2WD…
   / 4WD (dis)engagement lever? #2
The Kubota is the same. Contemplating a vertical lever extension to change this to a hand operation. Same with the park brake lever... too low.
One rocker pedal on the Kubota drive pedal is more than enough. Has taken me 80 hours to get close to in harmony with the teeter totter go pedal set up. lol
   / 4WD (dis)engagement lever? #3
The tractors with which I'm familiar used a lever depressed with the heel to engage the differential lock. This is used to put power to both rear wheels to help eliminate one spinning alone. The 4WD lever on my tractor (Kubota L2502) is pulled up to engage then disengages by pushing back down. You should never engage the differential lock while the wheels are turning.
   / 4WD (dis)engagement lever? #4
Right you are. The lock is not what the OP was inquiring about. He's asking about the 2WD/4WD lever.
   / 4WD (dis)engagement lever? #5
I think he has his leavers mixed up. what model and type tractor are we talking about?
   / 4WD (dis)engagement lever? #6
If his is like our Kubota, it could have the differential lock and the 4wd lever both next to each other under the left heel. So the OP could be referring to either one.
Both are engaged by pushing down with the left heel. Neither on should be engaged unless sitting still, because pushing either lever down while the wheels are turning is an even better way than inflation to spend a lot of money really quickly.
The first photo shows the tractor as it was new.... The problem I had with the 4wd lever was it kept being engaged by accident getting on and of the tractor. The solution was to mount the black gate latch you see in the photo.
rScotty
It’s a Kioti CK2610 HST... very similar to the Kubota pictured above... my 4WD and diff-lock levers are reversed with the 4WD lever being closer to the tractor centerline...
The diff-lock is spring loaded... I take my foot off the lever and the lock is released... (once the engaged splines are no longer binding...)
The 4WD lever "stays" wherever it's placed... which is the way it should be...
I'm just looking for an "easy" way to get from 4WD (lever down) to 2WD (lever raised)...
   / 4WD (dis)engagement lever? #9
The diff-lock is spring loaded... I take my foot off the lever and the lock is released... (once the engaged splines are no longer binding...).
Those sure are popular tractors. My neighbor has an early version.
Think of it this way: Most of the time you will be in 2wd. These tractors are 4wd assist; NOT full time 4wd. Compact and Utility size tractors under about 90 hp don't have a center differential, which means that the only way they have of getting rid of the built in "wind up" that happens to the drivetrain in 4wd is to slip a wheel.
Use 4wd when needed, and once through the rough spot put it back into 2wd. You can get by with leaving them in 4wd in slippery conditions if you are careful and especially without a FEL. Basically as long as a tire can easily slip, you are OK.
That's why the gate latch in the photo. It isn't to keep it in 4wd, a bit of unavoidable shaft windup will do that for you. The latch is keep something - like my heel - from knocking it into 4wd when it shouldn't be. Like when I'm traveling with a load in the FEL.
enjoy,
rScotty
…Use 4wd when needed, and once through the rough spot put it back into 2wd. You can get by with leaving them in 4wd in slippery conditions if you are careful and especially without a FEL…
That pretty much sums up what I’ve been doing…
I’m currently working on getting our driveway back in shape after winter… most times I can pull the BB full but occasionally I’ll need 4WD to keep going… then back to 2WD…
Dig into the pile of road base… sometimes I need extra traction…
I find myself leaving it in 4WD even when unnecessary… until I need to make a sharp U-turn and the tractor starts bucking…
I’ll continue to explore options to get the lever at a more user friendly level… or possibly work on the teeter-totter mod to make shifting into and out of 4WD a foot control affair
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A51572)
2007 International...
CAT 973 (A47384)
CAT 973 (A47384)
Bradley Electric Smoker and Cover (A51573)
Bradley Electric...
8ft Perforated Metal (A51573)
8ft Perforated...
CATALOG UPDATES (A53084)
CATALOG UPDATES...
