fschukar
Any one have any experience replacing seals/gaskets on the outboard end of the front axles on a tractor of this type? The leak appears to be around the axle itself. Is there a shielded bearing inside? I'm assuming I'll need to open the banjo-shaped cover over the the down drive so I'd need seals for this as well as whatever protects the axle.
Any help would be appreciated. Where to find such seals? Does it require a puller? Those kinds of things.
Thanks,
Fritz
Thanks,
Fritz
