Dirt Moving 4th Kubota B7300 Hsd stalls engine when loader is scooping.
   / 4th Kubota B7300 Hsd stalls engine when loader is scooping. #1
MatLayfield
It only does this occasionally. But its frustrating.
I just bought this tractor for 1000.00
They couldnt keep it running.
2100 hrs on engine
I discovered that the fuel bowl wasnt staying full.
Vacuum line was clogged and thats why it wouldnt stay running.
I plan on changing SuperUdt and Engine oil next week.
Oh and what are these 3 vacuum lines in the pic?
So any input would be greatly appreciated.
   / 4th Kubota B7300 Hsd stalls engine when loader is scooping. #2
Are you using the right technique with the loader, or are you too aggressive with the bucket? As you go into the dirt, you should be feathering up on the bucket so that it doesn't stall.
I have a Bx2230 and it never does this. I think i have got it figured out though i just purchased some hose to fix those lines.
thanks
   / 4th Kubota B7300 Hsd stalls engine when loader is scooping. #4
Your tractor pump puts out about 3.9 GPM, and at 2500 psi, that will take about 7 HP.
That leaves you with about 9 HP for tractor drive, and then the tractor will stall if using max tractor drive and full bucket use.
   / 4th Kubota B7300 Hsd stalls engine when loader is scooping. #5
thanks
Go ahead and tell us what those lines go to.
   / 4th Kubota B7300 Hsd stalls engine when loader is scooping. #6
Gary with that model BX he might not have the engine at high enough RPM to give the loader full hydraulics. I have always liked the older BX's because they required more then an idle to operate the hydraulic attachments so my old ears don't have to listen to hydraulic cavitation.
2015 Chevrolet Tahoe SUV (A55853)
2015 Chevrolet...
Zero Turn Mower (A55853)
Zero Turn Mower...
2024 CRATOS TWINCA ES500 ELECTRIC DUMPER (A57192)
2024 CRATOS TWINCA...
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A55758)
Year: 2017 Make...
24ft T/A Flatbed Equipment Trailer (A55788)
24ft T/A Flatbed...
2021 BOBCAT T66 SKID STEER (A52707)
2021 BOBCAT T66...
