4n1 on a L3830 size tractor
   / 4n1 on a L3830 size tractor #11
I have an L3830 with a WR Long UJ2 4in1 bucket. It is 72" wide and probably weighs around 600 with the tooth bar. It is perfectly matched to my tractor, in my opinion. I believe you need to have a little more ballast on the back when using one, although they have less capacity than a normal bucket. I also have a WR Long root grapple. Both have their uses, and I cannot imagine being without the 4in1 bucket with all it's usefulness.
About what would one pay for a WR Long 4N1 like yours?
Do you ever think it not heavy duty enough of a bucket and wish you had a heavier one? Thanks
   / 4n1 on a L3830 size tractor #13
Hi Rat...
Wr Long does make larger ones...next size up is the UJ1. It has more capacity, a little beefier and heavier. The UJ2 is perfect for my size tractor. It is heavy duty and stout enough for everything I have used it for, (moving concrete, etc). I am satisified with it. They also can add a spill guard to the bucket top/back for more capacity, which would be good for lighter material such as chips, manure, etc. I also got the WR Long electric diverter valve. More money, but I recommend it. Since it would be plumbed, having a grapple also would make you pretty diversified.
When I get back to the house, I will look on my sales receipt and PM you. It's good to go to several dealers and look at their aftermarket 4in1's to compare. I believe Kubota now has a 4in1 offered as an option. You may want to check that out. I do not know who makes it for them, or if they are making them themselves. One of the members here...(Builder, I believe), was looking at them. Maybe ask him, too. I am biased and like the WR Longs, though. Many people around here have them, also. Maybe Nelson Long can answer a question or two, since he is on our boards.
PS...If you are just doing brush, all you need is the grapple, like KennyD said...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2014 Gillig 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig 31+56...
2017 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2017 CATERPILLAR...
Land Honor Portable Screener (A50514)
Land Honor...
2001 Chevrolet Tahoe SUV (A50324)
2001 Chevrolet...
2016 VOLVO VHD TRI-AXLE DUMP TRUCK (A51222)
2016 VOLVO VHD...
