4N1 Bucket, Top-N-Tilt, Remote Joy Stick
   / 4N1 Bucket, Top-N-Tilt, Remote Joy Stick #11
Unfortunately the fittings and adapters dot com website has a $15 minimum order which means I'd need to buy 135 of these caps to get them via the website. I could probably use about $5 worth so I'll look around locally.
   / 4N1 Bucket, Top-N-Tilt, Remote Joy Stick #12
I have the HJ2-60 from WR Long.
Well, ISLAND, I got one of those Long HJ2-60 4 in 1s. I won an auction on
Ebay, and it will be shipped from PA. It has the aux valve and is set up
for a JD loader, so I will have some cutting/welding to do. Total damage:
$511 for the bkt, and $400 to ship.
   / 4N1 Bucket, Top-N-Tilt, Remote Joy Stick #13
Other than shipping costs it sounds like we got twin eBay deals. I ended up having a local welding shop do the modifications for me while I watched and it didn't take much more than half an hour to cut off the JD hitch and weld on a universal QA bracket. I ended up using two end pieces and a connecting bar rather than the full QA plate and saved about 50 lbs in weight.
Good luck with your conversion.
   / 4N1 Bucket, Top-N-Tilt, Remote Joy Stick #14
If mine is in as good shape as yours, ISLAND, I will be a happy camper.
I got mine from McGrew Equipment, who has a good rep and has been doing
these Ebay auctions for a long time. I have sold much bigger things on
Ebay, but I have never bought something this big there. I will post
when it arrives in a few weeks.
   / 4N1 Bucket, Top-N-Tilt, Remote Joy Stick #15
....it sounds like we got twin eBay deals...
My HJ2-60 (made for a JD 440 FEL) is less heavy duty than yours, ISLAND.
It has none of those side reinforcements, and no cylinder protection. The
curved part of the carcass is only 1/8", and I dented it just by handling it.
It weighed 326#, less the valve and main (long) hoses. I will find my ser#
to compare to yours if you have it. I am guessing mine is 5-10 y old.
   / 4N1 Bucket, Top-N-Tilt, Remote Joy Stick #16
Maybe I have the HJ-60 which is heavier duty. I did not realize the HJ2-60 weighed in at only 326lbs. As I recall I needed a comealong to pull the thing up a ramp to my trailer. I don't think I'd have needed that with 326lbs. I looked at the WRLong website and see that the HJ series does have the extra bracing metal too.
   / 4N1 Bucket, Top-N-Tilt, Remote Joy Stick #17
My HJ2-60 is all apart now, and it does not even HAVE a zerk for the lower
clevis of the cylinders. I will be beefing this unit up before completing my
install on my Kioti. I will start a new thread before I am flamed for hijacking
this one.
2014 Ag Spray Schaben Sidedresser (A56435)
2014 Ag Spray...
2012 International ProStar T/A Day Cab Truck Tractor (A56858)
2012 International...
1999 INTERNATIONAL 4700 24FT BOX TRUCK (A58017)
1999 INTERNATIONAL...
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
13046TX (A55973)
13046TX (A55973)
2025 Swict 78in Tooth Bucket Skid Steer Attachment (A56857)
2025 Swict 78in...
