495 Works in FWD but not Reverse
   / 495 Works in FWD but not Reverse #1
Kdeclercq
CaseIH 495
My 495 MFWD seems OK in forward gears but will only creep in Low 1st on flat ground. Big transmission problem??? Help
   / 495 Works in FWD but not Reverse #2
Do you have the hydraulic forward reverser?
It has the schuttle fwd reverse lever which seems to feel OK when you switch it, but as I said it will slightly move in reverse when its in Low 1 but barely.
   / 495 Works in FWD but not Reverse #4
Clutch gone in reverse clutch pack. Neighbour's 495 had the same problem. Was easy to fix with the tractor split.
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
2007 Ford Five Hundred SEL Sedan (A54815)
2007 Ford Five...
1992 CATERPILLAR 14G MOTORGRADER (A52709)
1992 CATERPILLAR...
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A55973)
2022 Ford F-250 XL...
TRANSMISSION JACK & TRACTOR CYLINDER (A54757)
TRANSMISSION JACK...
2022 Horizon Trailer (A55973)
2022 Horizon...
