495 Works in FWD but not Reverse
   / 495 Works in FWD but not Reverse #1
Kdeclercq
CaseIH 495
My 495 MFWD seems OK in forward gears but will only creep in Low 1st on flat ground. Big transmission problem??? Help
   / 495 Works in FWD but not Reverse #2
Do you have the hydraulic forward reverser?
It has the schuttle fwd reverse lever which seems to feel OK when you switch it, but as I said it will slightly move in reverse when its in Low 1 but barely.
   / 495 Works in FWD but not Reverse #4
Clutch gone in reverse clutch pack. Neighbour's 495 had the same problem. Was easy to fix with the tractor split.
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
Toyota Forklift (A55973)
Toyota Forklift...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2011 JACK COUNTY 130BBL VAC TRAILER (A58214)
2011 JACK COUNTY...
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
