'49 8n block repair
   / '49 8n block repair #1
jcgbranson
Illinois
Branson 3510i
I started up my 8n the other day only to find that there are two small pin holes in the block. The holes are directly behind the starter in an area that appears to be a casting mark. I am assuming that the block was a bit thinner at this point and has rusted through. Has anyone run into this issue before? Also, if anyone has any ideas on the best way to repair this, please let me know.
   / '49 8n block repair #2
Try JB weld.
   / '49 8n block repair #3
I am assuming it is just leaking a little coolant??
You could try cleaning it up a bit and JB welding it, and keep an eye on it. Welding it is another option, as is drilling and plugging it.
Got any pictures.
Thanks for the quick replies. Yes, just a bit of coolant. A steady drip. No pictures as I am techno challenged but I'll see if I can get some with a little help. How does the "drilling and plugging" work?
   / '49 8n block repair #5
try the JB weld before you drill.
   / '49 8n block repair #6
Yea, I would try JB first.
Also, be sure that it is indeed rust holes and not a small crack. If it is a small crack, a tiny drillbit and drill each end of the crack then JB weld.
There are a few different methods of drilling and plugging. Tapered plugs, or threaded plugs with sealant. But it dont sound like you have much meat (thickness) in that area and may not work well.
Personally, if it were mine, I'd pull the starter off, clean things up well, and put a little "tack weld" on each of the rust holes (if thats what they are) with a bit of nickle rod.
   / '49 8n block repair #7
Also, I wouldnt buy the quick setting stuff. Never had much luck with it on anything. It isnt as strong.
   / '49 8n block repair #8
Behind the starter there's a freeze or welch plug are you sure that's not what is leaking?
   / '49 8n block repair #9
carl beat me to it..... why not just repalce the leaking core plug before reacing for the glue.. ;)
I was wondering if it was some sort of freeze plug, but hadn't ever seen one like that. Round, about the size of a silver dollar? Doesn't appear to have any threads though and no clear way to remove it, so I just assumed it was a casting mark. I'm sure it's not a crack. Two little pin holes. How in the world do you replace it???
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
2008 ATOKA TRAILER & MFG. ATOKA TRAILER & MFG. (A53843)
2008 ATOKA TRAILER...
John Deere 5105 Tractor (A53117)
John Deere 5105...
2019 FORD F150XLT (A53843)
2019 FORD F150XLT...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
2024 John Deere 872GP Articulated Motor Grader with GPS Package (A52377)
2024 John Deere...
