48 SC
   / 48 SC #1
toycruiser
i won a 1948 case sc in a raffle an don't see where to check the oil.
is it missing a dip stick or a plug to remove to see if the level is correct?
thanks for any help.
   / 48 SC
i didn't see one.it has rained here for the last few days,
when the weather clears up i will look again..
would that be in the oil pan?
   / 48 SC #4
There are two small plugs on oil pan left side. highest one would be oil full,lower plug is one quart low. Add oil until it just starts to come out of higher plug. Hope this helps you.
   / 48 SC
Thanks James.i found the plugs you are talking about.
the level is good to go.
plan to put it in the oct parade an the cotton festival.
thanks to all..
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
2019 RAM 3500 (A52472)
2005 Superior Trailers VT130 T/A Vacuum Trailer (A51692)
2005 Superior...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
