48 " Mower Deck Spindles
/ 48 " Mower Deck Spindles #1
GTSRider
Cub Cadet 3000
On my 2nd mow of the season.... my mower deck self disintegrated
in seconds....
Here's what I found today after looking at it...
middle spindle was worn and caused brand new belt just installed to
ride off pulley, causing tension er spring to lodge under far left spindle pulley,
destroying it....belt is all tore up.... and now I need new spindle
for center blade , and new pulley for far left spindle, and of course new
belt.
I want to replace idler pulleys to while I am at it.
Can anyone tell me the best way to go on the spindle ?
They sell the kit for $125....
and what is the " trick " to remove and replace spindle unit ?
Thanks.
Pete
/ 48 " Mower Deck Spindles #2
If you remove the blade nut and the top nut (on the drive pulley) the spindle will just come apart on its own.
Would you recommend or not ...
to just replace bearings... or go the easy route , and buy the whole
spindle " Kit " as it is listed on the Cub Cadet parts fiche ?
/ 48 " Mower Deck Spindles #4
in seconds....
belt.
Thanks.
Pete
I found that an impact wrench is the easiest way to break the nuts loose. You can use a piece of 2 x 4 to lock the blade from turning. A piece of belt will help hold the pulley from turning to remove the upper nut.
Bob B.
Thanks Bob.... I was thinking along those lines...
Would still like to hear from anyone who has an opinion,
on whether to rebuild spindle, and just get 2 new bearings and seals...
or get the whole spindle kit ....
Big difference in price...
Thanks.
Pete
/ 48 " Mower Deck Spindles #7
It's not a big deal to rebuild them.
Thanks for your input.......then I will probably do that and save the $...
Got spindle out but now must remove damaged pulley.
Is that nut above Pulley usually any problem to remove ?
/ 48 " Mower Deck Spindles #10
See Bob Bainbridge's reply above....
2021 CATERPILLAR 299D3 SKID STEER (A64279)
2021 CATERPILLAR...
2004 DCT PUMP TRAILER (A58216)
2004 DCT PUMP...
2016 Jeep Compass SUV (A61574)
2016 Jeep Compass...
2022 EZ-GO ELITE...
Rhino Servis 2160 Ditch Bank Mower (A62180)
Rhino Servis 2160...
1996 International Water Truck with a Caterpillar Engine (A63688)
1996 International...
