48 farmall h generator wont charge
   / 48 farmall h generator wont charge #1
frustraed
pleasanton, kansas
1948 farmall h
my farmall h generator wont charge it has a wire off and if i touch it on anything it sparks any suggestions
   / 48 farmall h generator wont charge #2
Is it possibly the wire that goes on the connection marked BAT (for battery)..?? If this is the case, if you trace the wire back, it should go back to the ammeter. Current flows through the ammeter, then through a wire to the starter switch battery post, so as to charge the battery. So basically a direct link to the hot side of the battery.
If the connector has come off the end of the wire, crimp a new one on, and reconnect to that post on the regulator, and your charging problem may be solved.
2007 Allmand Night-Lite Pro Towable Light Tower (A51691)
2007 Allmand...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
2015 FORD F-250 SUPER DUTY (A53843)
2015 FORD F-250...
2006 Mercedes-Benz E350 Sedan (A51694)
2006 Mercedes-Benz...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
