48" deck locked up!
   / 48" deck locked up! #11
What about seals ?
-Larry
5030 said:
There isn't a spindle you can't take apart and replace the bearings in. From a commercial brush hog spindle to a TSC/MTD special, they all come apart and they all have one thing in common, stock bearings.
All you do is take it apart and get the outer diameter, width and inner diameter or use the catalog number stamped on the bearing and call or visit any bearing distributor.
In all the spindles I've rebuilt over the years, I've never bought any bearings from a dealer or OEM. The markup is way too high.
   / 48" deck locked up! #12
I for one carry them in stock! when I replace bearings I also change seals!
   / 48" deck locked up! #13
One thing to watch out for especially with MTD is they sometimes change the spindle designs for individual mowers without notification. For instance with my 44C deck the spindles were changed through the years to use aluminum housings mounted from underneath of the deck instead of the original steel housed ones that bolted above the deck frame. My original plan was to rebuild the spindles, but when I looked and saw there were 19 individual parts that composed the 44C spindles and the design was different, (plus the shafts I had looked a little worn at the bearing contact points) I had no idea what parts from the new design would interchange into the housings I had that were 25 years old. I wanted my deck to have 100% of the performance of a new one without compromise and I chose the new spindle route in the case of the old 44C deck.
-Fordlords-
   / 48" deck locked up! #14
I was headed down the rebuild road on my Woods until we broke a spindle housing. Used heat, hydraulic press, bfh, etc.
   / 48" deck locked up! #15
$120 for each spindle on my Woods rm360. Not that many parts if you want to keep the housing.
   / 48" deck locked up! #16
That's in line with what mine would have been. Found a whole good used deck for $225+tax. RM-48
   / 48" deck locked up! #17
Heavens to Mergatroid! Thats utter highway robbery.
-Larry
   / 48" deck locked up! #18
-Larry
What can I say, the actual price was 118 if I recall from an dealer on ebay. Local dealer was a lot more.
   / 48" deck locked up! #19
Timken spindles are usually pretty good, but anything can seize. When I grease I get a good amount of squeeze out below the spindle above the blades. I had a problem with my grease gun however. I appeared to be pumping in grease, but in actuality, no grease was going in. I knew this because I wasn't seeing any squeeze out. I had to make some adjustments to the compressor and gun and got it flowing again.
Glad we have this topic, I'm overdue by about 20 hours.
UNUSED JCT 84" HYD DOZER BLADES (A57193)
UNUSED JCT 84" HYD...
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
2015 Land Rover Evoque SUV (A53424)
2015 Land Rover...
INTERNATIONAL EAGLE ROAD TRACTOR (A57192)
INTERNATIONAL...
2013 FREIGHTLINER CASCADIA SLEEPER (A53426)
2013 FREIGHTLINER...
