47hp tractor ...
   / 47hp tractor ... #11
This past year was my second haying. First year I used a Kubota B7100 (18hp, 4x4, 1500lb with the loader), 7ft NH-451 sickle, kuhn GRS-21 2-basket rake and a 1950's-ish JD14T. (the 'bota looked pretty tiny hauling that stuff around but did 500 bales without much trouble!).
I upped to a 38hp International B-275 with a 2-stage clutch which made things a lot easier. I also traded up the baler for a JD 24T and did 2200 bales this past year. The 24T was great (after fixing a snapped-off input shaft). They're very similar to a 14T and easy to work on. The 24T has some refinements that are nice (and it's a foot narrower so it'll fit in my barn door).
With the bigger tractor and once I got the 7ft sickle adjusted correctly I mowed at 5mph. At slower speeds the grass would push over in front of the mower and cause clogs. You can't run over already mowed grass with a sickle or it'll clog, so corners and finishing the last row in a field can be tricky. The only real problem I had was going "downwind" on lodged grass, the mower wouldn't get/stay under it, but If I mowed the other direction it went through it fine... but that screws up patterns and geometry more than you think it would. If you do a poor job mowing the remaining "anchored" grass screws every subsequent operation up - causing ball-ups with a rotary rake and it gets tangled up in the baler pickup tines which is hard on the whole mechanism. The grass that gets pulled out by the pickup ends up a a green slug in the bale causing it to go moldy... so a good mower is really important.
I don't regret buying the sickle since it allowed me to get started with minimal investment of ~$4k including the IH tractor, but everything was non-functional when I bought it including the tractor. I did all the repairs and maintenance myself.
Now that I've determined I love haying, I can use the profit to justify upgrading some of the equipment - This year I hope to supplement my 2 basket Kuhn rake with a side delivery rake so I can combine windrows in 2 instead of 5 passes (for second cutting), and I'm keeping my eye out for a good deal on a used disc mower. I'd also like to get a proper hay wagon.
Ford Super Duty Pickup Truck Bed (A55973)
Ford Super Duty...
2014 Transcraft Trailer (A55973)
2014 Transcraft...
2004 Freightliner FL60 Ambulance (A56858)
2004 Freightliner...
2003 John Deere 110 Backhoe (A59213)
2003 John Deere...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
2016 Troy-Bilt 21in Push Mower (A55973)
2016 Troy-Bilt...
