4720
   / 4720 #1
wango tango
Peoria IL
looking at a 2012 4720. i believe it is tier 4 interim. what does this mean exactly, is there a DPF or DEF?
dealer says 58 hp, but i've seen 66 advertised.
35k for a cabbed machine with 400 cx loader, hydro, 505 hours and 2 rear remotes. r4 tires.
i really dont want DPF regens or DEF.
i'm comparing this against a new mahindra 2555 HST. almost same price, specs. mahindra is a bit wider, deere has 10 hp more.
   / 4720 #3
I have had a couple of the 4720 s nice tractor has 66 hp a 2012 is not a teir 4 so has no emission stuff you can move the tires around and make the foot print wider add some fluid to the tires on wide footprint very stable machine
   / 4720 #5
If it looks good cosmetically and is in good shape mechanically that is a good buy. The horse power for 2008 and earlier was 58, the 2009 models and later were increased to 66. I have been very satisfied with my 4520 for the last 6 years and is the same with 60 hp.
   / 4720 #6
Dealer may be referring to the PTO HP. As I recall the newer 4720 Nebraska tested at 58. I bought a 2013 cabbed 4720 w/400cx last summer. Similar hrs. Based upon the searching I did when I bought mine 35k would be a good price if it has been maintained. I paid more.
At 400 hrs a trans oil/filter change was due as well as engine oil/filter. Front axle is at 600 hrs so that is coming up. It is not difficult to do yourself but it will cost you. May be worth negotiating that in on a deal.
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A51691)
2016 Godwin CD150M...
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Forestry Mulcher (A53473)
2022 JCB 3TS-8T...
2025 CFG Industrial MX50R (A50123)
2025 CFG...
2019 Nissan Frontier Pickup Truck (A51692)
2019 Nissan...
2007 Ford F-150 Crew Cab Pickup Truck (A53422)
2007 Ford F-150...
