4720 Selonoid Valve Damaged
   / 4720 Selonoid Valve Damaged #1
kswrmk
John Deere 4720
Hi All. I have a 2012 4720 compact tractor with 4th and 5th remotes. They are currently hooked up to my top and tilt cylinders. My issue is while box blading, the top retaining pin on the tilt cylinder fell out and the cylinder started to work its way off of the pin. When I lifted the box blade the top of the tilt cylinder sheared off the aft electrical connection that goes into the 4th and 5th solenoid valves. I went to my Deere dealer to see if I could get replacement electrical connections and was informed that they are only sold as part of the solenoid valve (part number LVA16869) and could not be purchased separately. I was also given a replacement price of around 2400 dollars for the valve. OUCH! The electrical connection looks like a rectangular block that screws onto the end of the valve. It has HUSCO identified as the manufacturer and a part number of 54077-6 12VDC 39/11. I have been unable to locate this part anywhere and am hoping somebody here knows of a source for these parts and if it is replaceable at all.
Thanks Roadworthy. I have sent them an email requesting information on availability of the part or a replacement cross reference but have not received a reply back yet.
   / 4720 Selonoid Valve Damaged #4
Hello, I am wondering how you made out with the husco 54077-6 solenoid on the John Deere 4720?
2004 Honda Odyssey Van, VIN # 5FNRL189X4B025339 (A51572)
2004 Honda Odyssey...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2015 FREIGHTLINER...
2008 BMW 535xi AWD Sedan (A50324)
2008 BMW 535xi AWD...
