4720 Power Steering has hard spots when turning quickly
   / 4720 Power Steering has hard spots when turning quickly #1
Brown Dog
North GA
John Deere 5115M 5101E H260 5115M 540M all MFD
If I turn wheel slowly, it's ok.
But turning quickly - it has hard spots in it.
Can the pump have air in system OR can the pressure or volume be increased ?
I'm running throttle at 2,000 rpm's, because I'm Mowing in E-PTO setting.
Specs shows this 4720 P/S to have more flow than my older 4700, but the 4700 doesn't do this.
Any ideas ?
   / 4720 Power Steering has hard spots when turning quickly #2
Any ideas ?
Have you checked the screen in the transmission , changed the spin on filter .
   / 4720 Power Steering has hard spots when turning quickly #3
and don't forget about the filter on the high pressure side of the power steering pump. It's supposed to be serviced every 600 hour or so IIRC. How many hours on your machine?
I've just bought the tractor & it only has 250 hrs on it.
It still has original fluid & filter.
I mow strait runs, turn around & go back on 12-14 acres.
It's aggravating :-(
   / 4720 Power Steering has hard spots when turning quickly #5
I would take the hydraulic cylinder loose from the steering linkage. If it still did it then it is hydraulic related. If not it would be in the steering linkage.
I think I'll chk the screen in p/s side of pump
Thanks Arlen
   / 4720 Power Steering has hard spots when turning quickly #7
Charge Pressure Line (from SCU (optional through oil cooler) to Transmission) has a flow filter. It is located just before it goes into transmission.
JPC
   / 4720 Power Steering has hard spots when turning quickly #8
Are you in 4 wheel drive? That can cause some binding in the drive train on tight turns that can feel kind of jerky.
I'm in 2wd.
Where does this line with filter, go into the trans ?
I hadn't had time to diagnose.
   / 4720 Power Steering has hard spots when turning quickly #10
Jerkyness in steering can be caused by lack of pump flow. Not familiar with your JD models but parts breakdown shows a double pump so would suspect one section supplies the steering. Did JD use a different size steering unit on the 4720 Vs 4700.
If you run the engine RPM higher the problem still exist?
Does the steering wheel kind of lock up and then turn again or kick back and then turn again?
2017 Dodge Charger Sedan (A56859)
2017 Dodge Charger...
42FT X 36FT METAL GARAGE BUILDING (A58214)
42FT X 36FT METAL...
2831 (A58376)
2831 (A58376)
2024 LS MT242E MFWD Compact Utility Tractor with LL3003 Front Loader (A55302)
2024 LS MT242E...
2004 Freightliner (A57148)
2004 Freightliner...
2012 BIG TEX PIPE TRAILER (A58216)
2012 BIG TEX PIPE...
