4720 Fuel Leaking from Filter Primer
   / 4720 Fuel Leaking from Filter Primer #1
HobbleCreek
Utah
John Deere 4720
I have fuel leaking out (practically running out) from above my fuel filter. It's coming out around the fuel filter primer pump. I'm planning to replace the fuel filter today, but will that do the job or are there other seals in that fuel pump assembly that I need to look at replacing?
Well, I guess this thread will be more like a journal entry. My "local" (40 minutes away) JD dealer had the part in stock. The primer assembly included a new filter for under $61 including state sales tax. Just the removal of two bolts and a hose on each side, opened the bleeder valve, pumped the primer until fuel spewed from the bleeder valve, tightened the valve and pumped a few more times. Started up immediately. No leaks, no fuss, just a little muss.
   / 4720 Fuel Leaking from Filter Primer #4
:thumbsup: :thumbsup:
2024 Frontier FL1061S Hydraulic Flail Mower (A57024)
2024 Frontier...
POWERTEC INDUSTRIAL BRUSHLESS P.M.A.C SERVO MOTOR (A57192)
POWERTEC...
UNUSED FUTURE 1 SHANK RIPPER (A57193)
UNUSED FUTURE 1...
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
2015 Ford F-350 4x4 Pickup Truck (A55852)
2015 Ford F-350...
2021 Deere 333G (A53317)
2021 Deere 333G...
