4720 E-PTO engine rpm won't rev over 1750rpm
   / 4720 E-PTO engine rpm won't rev over 1750rpm #1
Brown Dog
North GA
John Deere 5115M 5101E H260 5115M 540M all MFD
My 5425 in epto setting - the eng will rev full 2600 rpm's.
I wanted this 4720 I jus bought, to rev a little over 1750 to speed up my rear finishing mower blades for a smoother cut.
I unplugged the rearward PTO sensor plug & plugged it into the forward sensor.
It now revs full rpm & illuminates the REGULAR PTO lamp when epto is engaged .
   / 4720 E-PTO engine rpm won't rev over 1750rpm #2
you better be careful doing that. That means you are spinning an implement that is built and rated to spin 540rpm a third faster than that. I sure wouldn't want that mower coming apart on my at that speed.
I knew I'd get flack for this lol.
I run a pulverizer a little faster like this in my poultry house litter.
I'm not talking but 200 or so engine rpm faster.
   / 4720 E-PTO engine rpm won't rev over 1750rpm #4
Your 5425 should not do that. There is a cable from the ePTO linkage that limits the injector pump to 1750 rpm range. It might be disconnected, broken, out of adjustment, or defeated.
Your 5425 should not do that ...
?? It's revved WFO in E-pto since purchased new in 2008.
It's a Mighty Fine piece of machinery with R4 Tires & Power Reverser tranny :D
4720 Engine only runs 1750rpm "IF" EPTO lamp is illuminated
On my 4720,
I wired E-PTO & regular PTO sensors Together TO the harness that Originaly went to the rearward sensor.
Now, my regular 540 PTO lamp illuminates when "Either" PTO setting is engaged & the engine will run full rpm if desired.
   / 4720 E-PTO engine rpm won't rev over 1750rpm #7
Dealer must not have checked the ePTO at predelivery service. Just a cable and throttle limiter at the injection pump.
I was looking for a 5X25 series with a power reverser & ePTO. I wanted R1 tires.
I got tubes installed & fluid in all 4 tires today.
Hooked up my 110" Befco RFM.
Set the engine at 2,000 rpm's IN EPTO setting.
The mower cuts so much smoother now :D
Man what a great combination.
The Hydro trans is FINE for mowin.
Much better machine than my Older dated 4700 power reverser.
Owner couldn't be Happier.
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A53472)
2023 New Holland...
2004 20ft Explorer Pontoon Boat and Trailer (A51573)
2004 20ft Explorer...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
2017 VOLVO VNL SLEEPER (A52577)
2017 VOLVO VNL...
NEW Work Saver Skid Steer/Sub Compact Grapple (A53472)
NEW Work Saver...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
