4720 ComfortGuard Cab Heighth
   / 4720 ComfortGuard Cab Heighth #1
TCowner
Platinum Member
SE Minnesota
John Deere 4720 Cab
Can anyone supply me with the heighth of the 4000 series tractor with the comfortguard cab with the 17.5-24 industrial tires?
   / 4720 ComfortGuard Cab Heighth #2
For whatever it's worth here is the only reference that I found and it is not specific....85.3 to 89.2 inches.
http://www.deere.com/en_GB/products/commercial/compact_tractors/4000_twenty/3020_4020_specs.pdf
Looks like it varies from 2168 - 2266 mm height with cab, which I presume depends on tire type. The tire size you list is the only option for R-4s that they list. I'm not sure if whether the relative diameter of the different tires provided with that tractor in other words is the R1 larger in diameter than the R4 or turf?
Millimeters per inch = 25.4; so the height in inches = mm/25.4 and that's 85.3 to 89.2 inches the way I figure it.
   / 4720 ComfortGuard Cab Heighth #3
The height with R1 tires is 95.4" from a brochure I have. I would guess the R4 tires to be 3-4" less.
   / 4720 ComfortGuard Cab Heighth #4
radman....That makes more sense than my calculation which was based upon the metric height quoted in that JD UK spec sheet. If you notice in that UK sheet, Deere quotes the height with ROPS as higher than the Cab which I'm 99.9% sure is incorrect.
   / 4720 ComfortGuard Cab Heighth #5
Actually, the height listed in the brochure for ROPS is 97.2", but it doesn't specify tire type.
   / 4720 ComfortGuard Cab Heighth #6
I have a 4720 with cab and R4's....it will just BARELY fit in my 8' tall garage doors.....barely!
   / 4720 ComfortGuard Cab Heighth #7
crap :)!!!! I have 95.4" of garage door height - If I had known it would fit I would have got a 4x20 series cab instead of my 3720 cab... ;)
Regarding the ROPS, they are much higher than the cabs. I had a 3320 open
which was much higher than the 3720 Cab I have (When it had the same tires). - That fit through
my 95.4" height door with not too much to spare.
I guess they figure you can fold the ROPS so they make them higher. Folding a Cab would be tough.. ;)
378137 (A54865)
378137 (A54865)
flooring (A55758)
flooring (A55758)
2007 Saturn Sky Convertible Coupe (A55853)
2007 Saturn Sky...
New/Unused Pallet Forks (A54865)
New/Unused Pallet...
2015 Ford F-250 Knapheide Service Truck (A53422)
2015 Ford F-250...
Reel Mower (A55851)
Reel Mower (A55851)
