4720 3pt hitch lift lever has loosened up / has no resistance - HELP
   / 4720 3pt hitch lift lever has loosened up / has no resistance - HELP #1
Brown Dog
North GA
John Deere 5115M 5101E H260 5115M 540M all MFD
4720 has 360hrs.
The 3pt lift lever use to have resistance like my 4700 & 5093.
It raises & lowers my mower fine.
Once raised, it now will slowly ease down because the lever eventually moves towards the down position.
There's no springs & nothing appears loose where linkage goes inside.
You can operate lever with one finger. Doesn't feel right.
Any ideas ?
   / 4720 3pt hitch lift lever has loosened up / has no resistance - HELP #2
Just tighten the friction plates that hold it in position, I believe.
The 3 threaded bolts around where it goes into the trans housing ?
I thought about that, as I seen jamb nuts on them.
   / 4720 3pt hitch lift lever has loosened up / has no resistance - HELP #4
A picture of that assembly would help confirm it.
   / 4720 3pt hitch lift lever has loosened up / has no resistance - HELP #5
From JD Parts:
Thanks JG & Beenthere :D
#'s 4 5 10 12 13 14 should clamp down on the lever, once tightened.
I'll try it & let you know.
Thanks guys .
   / 4720 3pt hitch lift lever has loosened up / has no resistance - HELP #7
My 5075e did the same thing after about 250 hours. The manual actually had good directions on how to tighten it back up, and I haven't had a problem since. Good luck with it.
I was wrong. It only had 2 bolts.
I loosened the jam nuts, tightened both bolts some, locked jam nuts down :
Bingo - feels like it did before & works flawless.
Thanks again for all your help & concern :thumbsup:
2013 JLG G9-43A Telehandler (RUNS) (SMOKES) (A50774)
2013 JLG G9-43A...
New 20' Run In Shed (A50774)
New 20' Run In...
2017 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2017 Dodge Ram...
2007 Ford Ranger Ext. Cab Pickup Truck (A50323)
2007 Ford Ranger...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-150...
