4707 code E13
   / 4707 code E13 #1
CNK70
Massey Ferguson 4707
Anyone know anything about this . Tractor losing power three indicator lights came on within minutes of each other.
Dropped from 2000 to 1790 rpm
All fluid levels are in the safe range .
   / 4707 code E13
All fuel that is placed in the tractor is double filtered from transfer tank .
   / 4707 code E13 #3
That "blowing air" light looks similar to my "clean air filter" light. Just a thought.
   / 4707 code E13
Changed
That's a DPF light I think.
Fuel filters, it doesn't have DEF nor Regen.
Found linkage off put back on but not knowing if clocked right. Restarted the tractor E13 code and engine light went away but still has that light on that looks like exhaust blowing. Running approx 10 min at full throttle as rpms dropping
   / 4707 code E13 #6
Not knowing any better but it looks like in the picture the set bolt tightened on the bottom of the shaft. I can just see a bright spot on the bottom of the shaft.
   / 4707 code E13 #7
Looks like the EGR linkage. That’s probably what lit up your little exhaust light, and why it’s not running properly
   / 4707 code E13 #8
Agree - its EGR linkage. There is a bulletin or something on it. The linkage came loose and is out of adjustment. Easy fix.
   / 4707 code E13
It's at dealership for the reset of egr and flash codes . Thanks
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2014 STEPHENS 200BBL TANKER TRAILER (A50854)
2014 STEPHENS...
New Lewis Brothers MFG DB2 Poultry Housekeeper (A51039)
New Lewis Brothers...
2014 Ford Flex SUV (A50324)
2014 Ford Flex SUV...
CATALOG IS A GUIDE ONLY!! (A50774)
CATALOG IS A GUIDE...
2014 KENWORTH W900 MID-ROOF SLEEPER (A50854)
2014 KENWORTH W900...
