4707 AC condensation drip
   / 4707 AC condensation drip #1
MinnesotaMorg
Central Minnesota
Deutz Fahr 6130ttv
hey all
where does your AC condensation drip when you're running it? For reference I shut off that coolant valve under the right side of the tractor and I notice a pretty significant drip coming down the back right side of the cab onto the axle. If this is normal then w/e. Ill try and get a video of it next time I run it.
   / 4707 AC condensation drip #2
The drain hoses for the A/C system drain down thru the RH and LH rear cab pillar - this is normal.
   / 4707 AC condensation drip #3
When you say "coolant valve" are you talking about the red handled knob on the heater hose near the exhaust side, under the cab door? Turning it off will stop the hot water from the engine from circulating through the heater in the cab, and make it easier for the AC to work.
I have two drip hoses coming out the back of my roof for condensation. One going down each corner of the cab.
yeah that valve under the cab door on the right/passenger side. Saw someone recommend to turn that off in the summer
2021 Redirective Crash Cushion Guardrail (A51692)
2021 Redirective...
2014 Nissan Rogue Select S SUV (A51694)
2014 Nissan Rogue...
2012 Chevrolet Silverado 2500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
2023 John Deere 6130M MFWD Tractor (A53342)
2023 John Deere...
