4700 Power Reverser Dies when put in gear and/or Engaging Elc PTO
   / 4700 Power Reverser Dies when put in gear and/or Engaging Elc PTO #1
Brown Dog
North GA
John Deere 5115M 5101E H260 5115M 540M all MFD
It's like the Elc Fuel Lockoff Solenoid looses power when using PR Lever or engaging elc PTO.
You can quickly shift PR lever back to neutral & eng will continue to Run, or disengage PTO immediately after engaging & eng will continue to run.
Short to ground possibly ? Fuses ok best I can tell.
It's did this 2r3 times b4 but always fixed itself after a few mins.
Any ideas Guys ?
   / 4700 Power Reverser Dies when put in gear and/or Engaging Elc PTO #2
Either the seat switch (Operator Presence Switch) or the neutral safety switch would be my first guess.
Thanks Roy,
I've bypassed my seat switch years ago so ill chk my jumper wire.
Makes sense now that you mentioned & it fixing itself previously - by me climbing in & outta seat on open station. I bet that's it.
My seat switch jumper wire was loose.
Runs like a top
55-Gallon Drum of Komatsu Hydraulic Oil HO 56-HE (UNOPENED) (A59076)
55-Gallon Drum of...
1998 6X12 Utility Trailer (A56859)
1998 6X12 Utility...
2019 KOMATSU D65PXI-18 CRAWLER DOZER (A52709)
2019 KOMATSU...
VINTAGE EVINRUDE OUTBOARD MOTOR (A58374)
VINTAGE EVINRUDE...
TANK MANIFOLD (A55745)
2009 FREIGHTLINER M2106 26FT BOX TRUCK (A58017)
2009 FREIGHTLINER...
