4700 Leaking Oil from front of motor
   / 4700 Leaking Oil from front of motor #1
AJT
I have a JD 4700 that has started leaking oil from the front of the motor (Seal). Has any had this problem and how bad is it to repair?
thanks
Re: 4710 Leaking Oil from front of motor
Sorry it is a JD 4710 not a 4700
   / 4700 Leaking Oil from front of motor #3
If sure it is the front seal, then I'd suggest getting the tech manual if doing it yourself (if no prior experience with seals).
If not sure, then look for a leaking valve cover seal (it happens).
Here is what the 4700 TM says about the seal. I'd expect the 4710 to be very similar.
And second shows removal of timing gear cover first (I suspect to get the seal out).
beenthere, Thanks for the reply, I do have the TM and I think I may try it my self. I work on old Military Vehicles so I think I can do it. But we will see.
Again thanks for the reply!!!!
:thumbsup:
   / 4700 Leaking Oil from front of motor #5
AJT
I think you can too. And would like to see some dialogue and series of pics as you proceed through the job. That would make a great thread to add to the TBN collection archives.
   / 4700 Leaking Oil from front of motor #6
AJT, probably is the Front Main Seal. I have a 4700 with 5600+ hrs. on it and around 4000 hrs. I had to replace mine. It is an easy fix, just time consuming. It's easiest if you remove the Rad, oil cooler, fan, not a lot of room in there for fingers. While you're in there you should check the steering hoses on top of the pumpkin for wear, cause you have to pull the same things too get to them.
David
beenthere and dsgsr,
Thanks guys for the reply. Will try to take some pics as I go. I may get started in a day or so.:thumbsup:
I just want to know what I was getting into.
   / 4700 Leaking Oil from front of motor #8
Wow, 5600+ hours! What is the overall condition? I have a 4700 as well that I bought new back in March 2000. Got 1249 hours on it now. Runs like a top, and I have worked it hard over the years, even harder in the last 4 months since I got a W.R. Long RBG-60 grapple and cleared about 20 acres of slash in hilly terrain after the loggers got done.
I paid, are you guys ready for this, $21,100 for it brand new with the 12F/12R PowrReverser and R4 tires. Ah, those were the days...
I have been very impressed with how this CUT has held up over the years given everything I have subjected it to. I have always been religious about doing the preventive maintenance, which I'm a firm believer in.
Just curious, how many miles on your 4710, and what have you been using it for?
   / 4700 Leaking Oil from front of motor #9
How would you calculate miles?
   / 4700 Leaking Oil from front of motor #10
I would say good condition. I have taken very good care of the maintenance. At 250 engine hrs. I started using Delvac 1 by Mobil for engine oil. It starts better with very little black smoke than My brand new Kubota M59 with a lot of white smoke. The key is using the machine, sitting is detriment to them. I have a little landscape/construction business and rental properties that keeps it going.
To Beenthere, approximately 40 miles equals 1-hr on a diesel engine. Of coarse that is different with diff. types of application but it is an industry average.
David
Massey Ferguson RB 4180V Round Baler (A50774)
Massey Ferguson RB...
Case IH 1063 Corn Head (A50514)
Case IH 1063 Corn...
2013 Ford E-250 Cargo Van (A50323)
2013 Ford E-250...
2005 Nissan Pathfinder SUV (A50324)
2005 Nissan...
4-27x10.5-15 Hauler Skidloader Tires & Rims (A50774)
4-27x10.5-15...
74in FEL HD Round Back Bucket (A52748)
74in FEL HD Round...
