47 B front hub question
   / 47 B front hub question #1
taggmann
John Deere B
Had a B on the farm, what seems to be a hundred years ago and I have seen many B's at shows and neighbors. Anyway I picked on up at a sale last week ( non-running).
My Question is ; The front hubs are huge and the steel wheels are dished out, I would prefer them in and as I was looking at the hubs I am sure they won't fit narrow? The hub has the the 6 lug hub but also a larger diameter 3 hole? anybody know what this hub is for? Or what wheel fits the larger 3 hole pattern?
Thanks
   / 47 B front hub question #2
Can you post a photo? What you have may be the F&H 273(IIRC) adjustable frt wheels
   / 47 B front hub question #4
Your hubs aren't the ones I was thinking about. There are 3 hub casting #s listed in parts cat #330 for a styled "B' < sn 201000.They are B918R,B2015R & A1553R. Can you check your hub casting #?
yeah I will. so you don't recognized them either? I just keep getting more curious.
Thanks
   / 47 B front hub question #6
Another possibility to limit your from reversing the wheels from the way they are now is "wrong wheels".
   / 47 B front hub question #7
Your hubs are a "heavy" factory John Deere hub. Deere produced to add weight to the front of the B's to help keep the front end down. The rims are not correct factory rims for that style of hubs. Call Mcgrew tractor parts at 866-521-9515 ask for Rich he will be able to fix you up with rims that will work with that style of hubs good luck!!!
Thanks for the info . I will give them a call.
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
2011 Kenworth T300 Jerr-Dan 21WSRB Rollback Truck (A52377)
2011 Kenworth T300...
40ft Sea Container (A52384)
40ft Sea Container...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2016 Ford Escape SUV (A51694)
2016 Ford Escape...
