47 B front hub question
   / 47 B front hub question #1
taggmann
John Deere B
Had a B on the farm, what seems to be a hundred years ago and I have seen many B's at shows and neighbors. Anyway I picked on up at a sale last week ( non-running).
My Question is ; The front hubs are huge and the steel wheels are dished out, I would prefer them in and as I was looking at the hubs I am sure they won't fit narrow? The hub has the the 6 lug hub but also a larger diameter 3 hole? anybody know what this hub is for? Or what wheel fits the larger 3 hole pattern?
   / 47 B front hub question #2
Can you post a photo? What you have may be the F&H 273(IIRC) adjustable frt wheels
   / 47 B front hub question #4
Your hubs aren't the ones I was thinking about. There are 3 hub casting #s listed in parts cat #330 for a styled "B' < sn 201000.They are B918R,B2015R & A1553R. Can you check your hub casting #?
yeah I will. so you don't recognized them either? I just keep getting more curious.
   / 47 B front hub question #6
Another possibility to limit your from reversing the wheels from the way they are now is "wrong wheels".
   / 47 B front hub question #7
Your hubs are a "heavy" factory John Deere hub. Deere produced to add weight to the front of the B's to help keep the front end down. The rims are not correct factory rims for that style of hubs. Call Mcgrew tractor parts at 866-521-9515 ask for Rich he will be able to fix you up with rims that will work with that style of hubs good luck!!!
Thanks for the info . I will give them a call.
2011 DODGE CARAVAN (INOPERABLE) (A53843)
2011 DODGE CARAVAN...
2019 DODGE RAM 2500 HD SERVICE TRUCK (A51406)
2019 DODGE RAM...
Electric Forklift Pallet (A50322)
Electric Forklift...
Krupp 300 Hydraulic Hammer (A52384)
Krupp 300...
2007 Allmand Night-Lite Pro Towable Light Tower (A51691)
2007 Allmand...
2017 TROXEL 130 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 130...
