4672 BH question
   / 4672 BH question #1
dty
New Jersey
Kubota 7610
When the dealer first dropped off my 7610 with a 4672 BH, the BH limiter rested snuggly on the lower 3ph links.
Now that I have taken the BH off and on a few times, the limiter sits about 1/8" - 1/4" above the lower links...they don't touch at all.
Is this normal or should they be touching? /forums/images/graemlins/confused.gif
Thanks.
   / 4672 BH question #2
I have the 4690, but you mean that the limiter bar is UNDER the lower arms, right?
It is a back up safety device from what I understand and does nothing if the top link bracket or pin holding the backhoe to it doesn't fail.
Mine has some clearance under the lower arms...
I consider it normal that there is some space beteen the limiter bar and the lower arms. Don't know if this is the right answer or not, but I comfortable with it in my case.
You certainly want the limiter bar to be below the lower arms though. VERY important that it is...
   / 4672 BH question
thanks Henro. The limiter is definitely under the lower links, so I guess I'm doing it right.
I've got BH installation down to 20 min so far /forums/images/graemlins/grin.gif I'd like to it get down to 5.
HUSKY 135 PSI AIR COMPRESSOR (A50854)
HUSKY 135 PSI AIR...
2022 Ford F-550 XL Crew Cab Forestry Chipper Truck (A49461)
2022 Ford F-550 XL...
2020 CATERPILLAR 289D3 SKID STEER (A51242)
2020 CATERPILLAR...
1995 OTTAWA SPOT TRUCK (A50459)
1995 OTTAWA SPOT...
2012 GENIE S-60X MANLIFT (A50854)
2012 GENIE S-60X...
2018 PETERBILT 567 (A50854)
2018 PETERBILT 567...
