Price Check 4672 backhoe price
/ 4672 backhoe price #1
Code54
Elite Member
Putnam Co. West Virginia
Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
Could someone please tell me what I should expect to pay for this hoe installed?
Thank you!
/ 4672 backhoe price #2
Should come in around $6k. I ended up with $5.4k for the unit and the rest went for assembly, setup and installation.
/ 4672 backhoe price #3
I should note that the "unit" includes the subframe. The dealer won't install the BH without it. I would also like to note that the subframe mentioned simply reinforces the frame of the tractor and does not provide any type of connection between the tractor and BH like on the BX23, BH75 and BH90.
/ 4672 backhoe price #4
<font color="blue"> I should note that the "unit" includes the sub-frame. </font>
What does the sub-frame look like. My manual for the B4672A does not show one. /forums/images/graemlins/confused.gif
/ 4672 backhoe price #5
The subframe is simple a pair of steel rails that connect the loader to the rear of the tractor helping spread the forces of the BH and loader across a greater area of the tractor frame. It is ordered seperately from the BH and works with all implements including a MMM.
/ 4672 backhoe price #6
The reason I was asking. In another thread, it was asked if frame bracing was needed. From a older thread on a 3PH BH it was determined that the bars were part of the 402 FEL kit on B27-2910 and B7800 tractors. Click Here
Did your dealer install a HD top link bracket?
/ 4672 backhoe price #7
If I may add my 2 cents, there is a subframe part that you can add, I have a B7610 with a 4672A backhoe.
The subframe part is called B4681 Support frame kit.
I have a PDF file showing this but unfortunately it has 200K and I can't attach it here. If is a PDF file I got from Tractorsmart a while ago.... ( another reason I will miss them).
I can Email-it to you if you want, just PM me with an E-mail address I will gladly send it to you.
New/Unused Landhonor No Till Seed Drill (A65583)
New/Unused...
Dexter trailer axles (A61567)
Dexter trailer...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
New/Unused CFG Industrial H15R Mini Excavator (A65583)
New/Unused CFG...
New 11'x19' Steel Carport with 10' open sidewalls  (A62679)
New 11'x19' Steel...
1996 John Deere 7700 (A64119)
1996 John Deere...
