4630hst value
   / 4630hst value #1
930ck
southcentral kansas
allis d 17/ case 930, 1370/ kubota L5740
Found a 4630 hst fwd fel with 600 hr salesman not sure of yr, between 03 and 06, no rear remotes asking 21000 seems a little high so thought i would ask. Just found this site and have been looking for a tractor with around 50 hp with hydro fwd fel but with at least one remote. Main u:cool:se will be 6 ft mower and piling brush. Any recomemdations are helpful . Thanks.
   / 4630hst value #2
That is a bit high for an open station, is it a cab tractor?
He should be able to give you a much closer date.
You can determine when the engine was built Year & Month using this: Kubota Engine America - Compact Diesel Engines
If they stick to that price they should also give you a Couple Pair of rear remotes AND plumb in a third function on the loader (for aux hydraulics, grapple or 4N1 bucket use).
KennyV
   / 4630hst value
Thought it was on the high side (no cab) it is at a jd dealership but kubota dealer said adding one remote would be close to $1000 and he could get me in a comparable new tractor for $26000 including one rear remote. Was wanting to get a used tractor but it appears that what most have told me may be cheaper in long run to buy new. Wanting to stay with local brands(kubota,jd,caseih,mahindra)
Gravelly Pro-Turn 148 48in Zero Turn Mower (A48082)
Gravelly Pro-Turn...
2008 Ford F-250 Knapheide Service Truck (A50323)
2008 Ford F-250...
2016 KENWORTH T660 SLEEPER (A50854)
2016 KENWORTH T660...
UNUSED Black Outdoor Patio Fabric Screen Cover (A50860)
UNUSED Black...
2010 CAT 140M MOTORGRADER (A50854)
2010 CAT 140M...
2007 FORD F-450 (A50854)
2007 FORD F-450...
