4630 wiring
   / 4630 wiring #1
Patf10
Holbrook, Pa
Ford 3000, Ford 4630 4wd, New Holland 1720, Kubota B7100HST
I have a ford 4630 that i am trying to get lights working on. It doesn't have a cab and the headlights are fender mounted. The switch on the dash is two position. What is each position supposed to do? One does flashers and no head lights and the other is both? There are two wires that run to the back of the tractor but i only get power to one of them regardless of the position of the headlight switch. Having trouble finding a wiring diagram that is applicable to my model. Even in the repair manual.
Thanks for any input.
Pat
   / 4630 wiring #2
A bit late here. I have a Ford 4610 with the 2 position switch. First position flashing lights, constant on rear light and power for rear work light. Second position you get all the above plus headlights. I got rid of the factory lighting and added LED flashers and LED headlights. Headlights mounted up high to clear FEL. They work great.
Miller Spectrum 500 DC Plasma Cutting System (A54811)
Miller Spectrum...
2012 International (A55973)
2012 International...
200722 (A51247)
200722 (A51247)
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
Hose Reel (A55758)
Hose Reel (A55758)
