4630 wiring
   / 4630 wiring #1
Patf10
Holbrook, Pa
Ford 3000, Ford 4630 4wd, New Holland 1720, Kubota B7100HST
I have a ford 4630 that i am trying to get lights working on. It doesn't have a cab and the headlights are fender mounted. The switch on the dash is two position. What is each position supposed to do? One does flashers and no head lights and the other is both? There are two wires that run to the back of the tractor but i only get power to one of them regardless of the position of the headlight switch. Having trouble finding a wiring diagram that is applicable to my model. Even in the repair manual.
Thanks for any input.
Pat
   / 4630 wiring #2
A bit late here. I have a Ford 4610 with the 2 position switch. First position flashing lights, constant on rear light and power for rear work light. Second position you get all the above plus headlights. I got rid of the factory lighting and added LED flashers and LED headlights. Headlights mounted up high to clear FEL. They work great.
2022 Lonestar (A55973)
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
Year: 2023 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2023 Make...
2019 Deere 35G (A53317)
2019 Deere 35G...
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
