4610 starting problem
   / 4610 starting problem #1
Kenkjsm
Perryville, MO
Ford 4610 Utility, John Deeere 3020 Gas
I am having trouble with my 4610 starting consitently. I used it all morning shutting it down periodically. Parked for about 2 hours and I got lights on the instrument panel but it would not start. I have replaced the starter switch. I noticed the starter cable is bad. I priced one from Ford and they want $70.00. What is so special about this cable? Can I just get one from the autoparts store? I can't find anything on the gauge of the cable and am not sure the cables on the tractor are the correct size as I purchased it used.
I still haven't checked the neutral safety switch which I understand could be sticking.
As a side note, when I was changing the fuel filters, I could not turn the starter off with the key, so it just cranked until it wanted to stop. I'd say 30 -40 seconds each time.
   / 4610 starting problem #2
I have to wiggle the range shifter while turning the key every time I start mine. Those safetly switches are known to be a problem.
If the tractor continues to crank without the key being turned, there's a good chance that your solenoid is sticking. They can "weld" themselves, resulting in what you described. Usually the battery gets VERY hot as a result. I have had to run for wrenches to disconnect a smoking battery on more than one occation because of a stuck solenoid.
Thanks for the input. I was thinking the solenoid also. And as for startinging it seems I have to have both selectors in neutral and the clutch in to even have a chance. Just kind of frustrating.
OK Does anyone know how to get the starter off? I can't seem to get a wrench or a socket on the bolt on the inside. The one that would be right between the block and the starter.
   / 4610 starting problem #5
On our 3910, which should be about the same, I used a 1/4" drive ratchet and two extensions to reach the whole length of the starter, and then had no problem.
Thanks. I was wondering if 1/4 drive would turn it. I'll give it a try
2013 VOLVO VNL (A55745)
2013 VOLVO VNL...
1000000 (A47477)
1000000 (A47477)
Atlas Copco XAS90JD Portable Air Compressor (A57453)
Atlas Copco...
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
204158 (A57193)
204158 (A57193)
2020 FREIGHTLINER CASCADIA SLEEPER (A57880)
2020 FREIGHTLINER...
