4610 cannot shift into 4th or 8th after neutral switch replacement
   / 4610 cannot shift into 4th or 8th after neutral switch replacement #1
jackclay
hampton, florida
ford 4610
After replacing neutral switch onFord 4610, cannot shift transmission (8 speed hi/lo floor shift, nonsyc.) into 4th or 8th all other gears are just fine. any ideas?
   / 4610 cannot shift into 4th or 8th after neutral switch replacement #2
If you take the new switch out again will it shift correctly? Wrong switch? Something moved while it was apart? Did the shifting act that way ever before?
Jim
Same switch as old one but works, had 4th and 8th before, all looks well inside and the thing shifts great but only 6 speed. linkage lines up what seems to be correct, got me stumped. as far as I no did not adjust or tinker with fork arms.
seems like something has indeed moved, like one of the linkages, have to find a diagram of proper linkage, gotta be close to solvin thisng. thanks my man.
2019 Bobcat 3400 4x4 Utility Cart (A51691)
2019 Bobcat 3400...
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51692)
2014 International...
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
2021 CATERPILLAR 262D3 SKID STEER (A52705)
2021 CATERPILLAR...
2020 John Deere 1025R MFWD Compact Tractor (A55302)
2020 John Deere...
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A54607)
2015 GREAT DANE...
