4600 SU losing power
/ 4600 SU losing power #1
marty
Bronze Member
Mid West
Boomer 33D
Has anyone ever had an engine lose power, such as at 2200 RPM's going down the road and then drop to 1400 RPM's and then come back up after a short moment? We replaced the fuel filter and it seems to make no difference. It certainly appears to be a fuel problem. Any thoughts on what one would test or replace? Thanks in advance for your thoughts!
/ 4600 SU losing power #2
hi a very big problem on these tractors is the fuel valve in the under the tank the screen on the valve falls off and the small hole in the valve plugs up drain the tank and remove the valve clean or replace this should take care of the problem good luck Gary
Generator (A61572)
Generator (A61572)
2006 Sea Ray Sundancer Boat w/ Loadmaster Tri-Axle Boat Trailer (A61574)
2006 Sea Ray...
Kubota L3901HST
Kubota L3901HST
2019 Isuzu NPR 14' Box Truck (A62613)
2019 Isuzu NPR 14'...
2023 John Deere 317G Compact Track Loader Skid Steer (A61572)
2023 John Deere...
2019 HYDREMA MX14 TIER 4 MOBILE EXCAVATOR (A63276)
2019 HYDREMA MX14...
