4600 JD front diff lube
/ 4600 JD front diff lube #1
kellytheaker
Rockwood Ontario
110 TLB
am i to use 85-90 in the front axle or hydrollic fluid , it is slightly low and would like to top up. thanks in advance
/ 4600 JD front diff lube #2
Use the Low Viscosity HY-GARD in the front MFWD differential. It's the same as the fluid you use for your Hydrostatic transmission and hydraulics.
I haven't hit 500 hours on my 4600 yet - so I haven't had to change mine. I will be there soon, though. I don't like the dipstick that you use to check it as the color of the fluid doesn't register very well on it when you check it. /forums/images/graemlins/crazy.gif
Good luck!
-Bob
/ 4600 JD front diff lube #3
I think you are giving him the wrong answer. I believe he is right, to use the gear lube, not the Hy-gard. That is gears not the same as the transmission and hydraulics.
/ 4600 JD front diff lube #4
In my 990 and 970 you use GL-5 gear lube I prefer 80W 90 but I noticed for the new 20 series Deere's they recommend hydro fluid. I can't remember what my 4300 took in the front end but he could be right it is the hydro fluid.
/ 4600 JD front diff lube #5
It's what both manuals - on-line and printed - say to use. So I hope it's right....
-Bob
/ 4600 JD front diff lube #6
Yep, you're right Bob. The manual states to use either Low Vis Hy Gard or Hy Gard. And from what I'm understanding from JD is they are recommending using Low Vis Hy Gard for all climates, with the HST.
Also, for those that have the older 4000 series tractors, they did change up the service schedule on the hydraulic fluid change and went to a bigger hydraulic filter. This was a few years ago so I doubt you could even get the old type filter anyway.
Compact Utility Tractor Service Interval Change and Improved Hydrostatic Filter
/ 4600 JD front diff lube #7
Thanks, Billy... I try to stay on top of this stuff as best as I can and sometimes even the local JD dealer gets miffed because my information is more up-to-date than theirs! /forums/images/graemlins/shocked.gif
The change in filter was noted in the on-line manual - but not in the printed version. When this changed it took some time for the dealers to catch up - my recommendation is that one always be wary to confirm parts, procedures, etc. before doing their own work. The web (and this site) is a better source than what the dealers can tell you - unless they read TBN too... /forums/images/graemlins/wink.gif
-Bob
2012 Ford F-350 4x4 Ext. Cab Pickup Truck (A61568)
2012 Ford F-350...
METAL SIDES FOR HARDEE TRAILER (A63291)
METAL SIDES FOR...
DRUMS ON A PALLET (A63291)
DRUMS ON A PALLET...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
LOT OF MISC BAR JOIST (A63291)
LOT OF MISC BAR...
2019 INTERNATIONAL 4300 26FT BOX TRUCK (A59912)
2019 INTERNATIONAL...
