4600 Ford Trans & Hydraulic lines oil
   / 4600 Ford Trans & Hydraulic lines oil #1
Danescountry
Symsonia, KY
Ford 4600
What oil is used in Trans & Hydraulic lines?
   / 4600 Ford Trans & Hydraulic lines oil #2
utf fluid meeting m2c134D spec is used int he trans, and the rear/hyds sump.. power steering too.
Thanks. How much does it take?
   / 4600 Ford Trans & Hydraulic lines oil #4
you will have to check your manual on that one.. or fill till the check plugs are happy.
i'd plan for 'quite a bit'
i know my 5000 takes a couple pails plus.
i don't recall what my 4600 took when i serviced it earlier this year.. but i buy utf by the 5g pail.. multiple pails at a time.. :) it will for SURE take well over 5g
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
Etnyre 2000 Gal Asphalt Dist. Truck (A47477)
Etnyre 2000 Gal...
2002 Ferguson SP915RE Ride-On Pneumatic Asphalt Compactor (A52377)
2002 Ferguson...
Mobile Transformer and Power Substation Portable Power Supply (A55218)
Mobile Transformer...
2014 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400 LB Crane Service Truck (A53422)
2014 Ford F-550...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
