460 utilty Clutch
/ 460 utilty Clutch #1
shadma5
Sheboygan Wi.
International 450 utility
I restored a 1958 utility to use for odd jobs and snow removal. I ran it over the winter and am having a problem with the clutch disengaging when depressed. I have been having to pull the TA lever to shift. I installed a new clutch and throughout bearing last fall. If I adjust for more travel then the clutch actually starts slipping. An thoughts as to why it won't disengage completely?
/ 460 utilty Clutch #2
#1 flywheel warped did you have it trued when you did the clutch?
#2fingers on pressure plate out of adjustment did you check the height after it was installed on flywheel?
#3 clutch plate installed backwards.
#4 rust in clutch
#5 pilot shaft bushing to tight or seizing
/ 460 utilty Clutch
Thanks for the info. I didn't turn the flywheel seemed flat with a straitedge but you never know. When I dissasemble I'll check all these.
SB
/ 460 utilty Clutch #4
IS this a two step flywheel? You do need to do the TA adjustment with the clutch.
Hydraulic Breaker Excavator Attachment (A61567)
Hydraulic Breaker...
(1) UNUSED 18X9.50-8 TIRE ONLY (A62130)
(1) UNUSED...
2005 Kubota L3130 (A60462)
2005 Kubota L3130...
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
LOOK! (A63109)
LOOK! (A63109)
2000 Freightliner FL112 T/A Dump Truck (A61568)
2000 Freightliner...
