460 loader on an 870??
/ 460 loader on an 870?? #1
yandeereguy
Somewhere usa
John Deere 950 2wd John Deere 870 MFWD, John Deere F525 mower, John Deere F725 mower, John Deere F510 mower, John Deere Lx172 mower
Okay I know what your all gonna say.. no way! way to big... but say I can get a 460 loader (no bucket) for a good price, and can do all the fab work to make it work.. are the cylinders gonna be too big??
If I could find a 440 loader I would'nt be considering this but I can buy the loader and a brand new Miller 212 mig for less than half the cost of a new 300cx
The biggest problem with this is idea,* lines are on wrong side of tractor,* have to cut 4500 mount tube and weld on to fab mount (no biggie),* will more than likely have to cut out the brace that attaches to the front of the tractor and either modify or completly refab.. and outside to outside width may be an issue on the post..
/ 460 loader on an 870?? #2
Even with the 460's capacity, the 870 probably doesn't have the hydraulic capacity (pressure or volume) to get you in too much trouble.
You're not going to do the lifting (weight or speed) you could if the loader was installed on a 4600 or 4700.
Definitely do some measuring first...I think the main problem is going to be the spacing between the masts. The 460's mounts (on the 870) may not be wide enough.
Now, I'm writing this from memory...been a while snce I sat on an 870 or even seen a larger Deere CUT. So do your homework first...you may find out your savings won't be too good.
/ 460 loader on an 870?? #3
More trouble than it's worth. It very seldonm works out to make something "fit" something it wasn't intended to.
I guess I'll just leave it alone, I'm putting a backhoe on the back of my 870 and will just use weights instead of a loader to counter balance.. I finally found a loader for my 950 at the same time I found the 460 so I'll just get the right loader for my 950 instead..
Of course I will still need to rebuild the 950's engine :(
