460 loader grease zert won't take grease
   / 460 loader grease zert won't take grease #1
Boiler74
Indiana (Purdue country)
John Deere 4710
460 loader grease zert won\'t take grease
Ok, need help. Been greasing my loader zerts every 10 hours, because I use it so much. Now one of the zerts won't take grease. I put the gun on it, and squeeze as hard as I can, and can't get it to go. So I pulled the zert, cleaned it up, and then put it in the grease gun and it took grease fine. So I reinstalled it, thinking it would work. No dice. Same problem all over again. So anybody ever had this problem? And solutions?? I need to grease this point - been using the loader a lot. All help appreciated.
Thanks,
Josh
   / 460 loader grease zert won't take grease #2
Re: 460 loader grease zert won\'t take grease
Josh, you don't say what position the loader is in at the time you tried to grease it, but if the zerk is OK (as you indicated) then I would suspect the metal pieces between which you want the grease to go might be pressed together too tightly. I'd try moving (flexing) that particular joint and try again. In other words, if you were trying to grease it with the loader in the air, I'd lower it and try again, or vice versa.
   / 460 loader grease zert won't take grease #3
The pin may be pressed against the Zerk hole. Try starting the tractor and moving the loader until the pin is pressing against the other side of the bushing.
   / 460 loader grease zert won't take grease #4
Bird took the mords right out of my wouth.
   / 460 loader grease zert won't take grease #5
Did you try moving the loader to a different position.Sometimes more or less pressure on the bushing will allow the grease to flow.
   / 460 loader grease zert won't take grease #6
lol
Thanks guys. I'll try that in the morning. All the other points would take it - couldn't figure it out. Hope this will work.
Gotta say I love this site!! Help in minutes.
Thanks,
Josh
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
2017 Chevrolet Tahoe SUV (A56859)
2017 Chevrolet...
2013 BMW X5 xDrive50i AWD SUV (A56859)
2013 BMW X5...
2008 Ford Ranger Pickup Truck (A54814)
2008 Ford Ranger...
LIMA MAC 60KW GENERATOR (A55745)
LIMA MAC 60KW...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
