460 Loader Attachments Compatable with 300cx?
/ 460 Loader Attachments Compatable with 300cx? #1
HarleyEnough
I found a pallet fork in a local paper for sale. It's the JD brand with floating forks. Says it's 54" wide and came off a 460 loader with quick attach. Will this also fit a new 300cx loader with the standard quick attach?
Distance (horizontally) between upper quick attach points on the inside is 36 3/4". Distance (Vertically) between upper and lower quick attach points is 15". I would measure my own bucket myself but my 3320 won't be here till next Friday! Thanks for the help.
/ 460 Loader Attachments Compatable with 300cx? #3
Should fit fine, no problems.
Just make sure the "quick attach" they refer to in the add is not the Bobcat style.
/ 460 Loader Attachments Compatable with 300cx? #4
/ 460 Loader Attachments Compatable with 300cx? #5
Yes, if you have the Deere type of QA on your 300CX.
/ 460 Loader Attachments Compatable with 300cx? #6
/ 460 Loader Attachments Compatable with 300cx? #7
I will go out and measure mine for you now. BRB.
Yes, 15" and 36 3/4" are correct for the JD QH 300CX.
Mike
/ 460 Loader Attachments Compatable with 300cx? #8
Mike
Thanks guys for all the help!! Don't know what I'd do without the access to this info tbn provides!
