46 JD model A
/ 46 JD model A #1
RottenGround
Bronze Member
Ozark, Arkansas
1974 JD 830, 1946 JD Model A
Just have purchased 46 JD Model A tractor, good resto project has had 30w non detergent oil run in engine. Engine doesn't smoke but wondering about changing to a detergent oil. Can I run 80-90 gear in tranny and does the powertrol use same sump or separate thanks
/ 46 JD model A #2
not sure about tranny oil but you can change to to detergent but non detergent is still available might want to keep it the same just a thought keep this in mind once you go to detergent oil you cannot go back
