Tires 46 BH Subframe/Front Tire Issues
   / 46 BH Subframe/Front Tire Issues #1
JasonL
Pendleton, IN
JD 4110
Does anyone with a 4110/46BH have a problem with their tires rubbing on the subframe mounts when turning hard? I installed the BH myself, and I can't seem to keep this from happening. I even tried to turn the brackets around( which makes the pins nearly impossible to put in!) but the tire still rubs. Am I doing something wrong? I'm afraid I might tear up a tire.
   / 46 BH Subframe/Front Tire Issues #2
Does the 4110 have an adjustable wheel stop on the axle?
Good Question! I don't know. I'll have to check tomorrow. If so, that might take care of the problem. We'll see.... Thanks, Jason
   / 46 BH Subframe/Front Tire Issues #4
Just an FYI.... I have the 2520 with the 46 and it had the same issue as installed. The dealer called the factory and didn't get much help. They cut off the exposed ends of the u-bolts flush with the nuts. Now it clears, but barely. They said that it was partially due to having turf tires which are larger than the R3s or R4s. So, you may consider different front tires if you can.
Good Luck!
Fud
   / 46 BH Subframe/Front Tire Issues #5
That may be the case, I didn't notice any issues on my 2520 with R4s. Now that I'm hearing about these issues I wish I had taken more pictures of the install before I unmounted it so I can get it working again - no excuse since I've got a nice DSLR...
I have R4's on my 4110. The subframe brackets on it fasten square with the ground (not angled like I think they do on a 4115/2520) So grinding off the bolts won't help. I haven't been able to check to see if there is an adjustable wheel stop yet. My tires actually catch the side of the bottom plate. I suppose I could grind on it a little- But there doesn't appear to be very much metal there now (between the corner and the bolt hole) I'll just have to see... THanks Jason
   / 46 BH Subframe/Front Tire Issues #7
I have a 2520 with the 46 B/H frame. I have been fighting the tire issue hitting the loader frame and mounting bolts for the B/H for several months. JD's solution so far has been to offer to buy back the tractor. (Not going to happen, I like the 2520's capabilities)
JD is now working on new brackets for the B/H subframe to alleviate the U-bolt from tearing up the tires. The issue is aggravated when you are on uneven ground. The uphill wheel is shredded by the bolt (see attached pic). JD also has said that the fix will be to go the R-4's. Turf tires are to big and will always hit the loader frame and B/H bracket. I bought my tractor with turf tires so I don't tear up the lawn. It seems to me that JD is being very arrogant and not really addressing the issues.
   / 46 BH Subframe/Front Tire Issues #8
Now I see there the problem is, my 2520 with R4s doesn't seem to have that issue. I've attached a few pictures to show what my tires look like when fully turned. If I can provide any measurements or other pics to help, just ask.
Wow! My situation is not nearly as bad as yours (f2000ez)!! Evidently JD has got some work to do on the 2520.:( I can't believe I am having problems with my 4110/46BH though because they have been around long enough you would think they would have the kinks worked out.:confused: Is there anyone with a 4110/46BH with similar issues??? Jason
   / 46 BH Subframe/Front Tire Issues #10
JasonL - I have the 4110 with 46BH & FEL. Haven't noticed any issues in the 18 months I've had the set-up but I haven't looked for them either.
I'm putting my BH on this weekend, will let you know what I see.
-Norm
Norm- Thanks for the help. Actually my tires will rub whether the BH is on or not. It is the corner of the subfame bracket that is causing the problem. I think I have moved the bracket in as close as possible to the engine, but it still rubs. Thanks- Jason
   / 46 BH Subframe/Front Tire Issues #12
Jason,
Raining here today so I'm not going to futz with BH but here's a pic of my set-up; 4110, loader frame w/46BH support attached, turf tires....there's over 4 inches of clearance between tire and closest points on the BH mount.
-Norm
   / 46 BH Subframe/Front Tire Issues #13
Put your tractor on uneven ground, where the front axle is hard against the left or right stop, and your tires will hit the loader frame. It doesn't matter about the tire size.
   / 46 BH Subframe/Front Tire Issues #14
Tried it, pretty darn close but doesn't hit. Turf tires.
-Norm
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 CATERPILLAR 938M WHEEL LOADER (A60429)
2019 CATERPILLAR...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2018 F550 Bucket Truck (A56438)
2018 F550 Bucket...
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
